| Message |
Hi, CTS is located on the hardpipe. You need to find the yellow one, with 3 little connector inside. Clean it with connection grease or spray. Check for deformation. Switch off your A/C. If the connector is not on the right place or no connection your engine will idle at 1200 rpm and the A/C vent. will run. If the sensor work well, your idle is fine. Regards, Attila
